Ga door naar hoofdinhoud
Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement
Wat je nodig hebt
  1. Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement, Lightbulb: stap 1, afbeelding 1 van 3 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement, Lightbulb: stap 1, afbeelding 2 van 3 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement, Lightbulb: stap 1, afbeelding 3 van 3
    • Turn off the power to the fan and light before you begin to avoid injury.
    • Twist off the cap that holds the glass dome still.
    • Slide the hardware covering the glass and allow it to hang on the end of the pull chain.
  2. Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 2, afbeelding 1 van 2 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 2, afbeelding 2 van 2
    • Twist off the bolt that holds the glass dome up.
    • After this, it is helpful to have a second person. If you let go of the dome, it will fall and possibly break.
    • Until you screw the bolt back on, make sure you have someone holding the dome in place.
    • You are working with a glass dome. If the dome drops it could break. Glass shards can cause injury.
  3. Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 3, afbeelding 1 van 2 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 3, afbeelding 2 van 2
    • Slide the glass dome down to reveal the light bulbs.
    • Unscrew the old lightbulbs and replace them with the new ones.
  4. Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 4, afbeelding 1 van 2 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 4, afbeelding 2 van 2
    • Slide the dome back in place to cover the light bulbs.
    • Replace the bolt to secure the dome.
    • Once the bolt is in place and the dome secure, you can let your arms rest.
    • Don't screw the bolt too tightly. If you do, you may crack the glass. You also need to be able to rotate the dome in place.
    • Rotate the dome until the fan cord aligns with the hole correctly. Try pulling on it to test. You will need to twist the dome until it lines up correctly.
    • If you don't hear a click, it is tangled.
  5. Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 5, afbeelding 1 van 3 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 5, afbeelding 2 van 3 Harbor Breeze Lake Canton Ceiling Fan Lightbulb Replacement: stap 5, afbeelding 3 van 3
    • Realign the hardware at the base of the glass dome and and screw the cap to secure.
    • Check that all of the holes align with the fan cord. Pull the cord to confirm you hear a click.
    • If necessary, rotate and work with the chain to untangle it.
Conclusie
You now have all the information to replace your own ceiling fan lightbulb. While a few things may differ for different brands, the general idea should be the same. I hope this was a helpful experience for you, enjoy your light!
Jamie Blankenship
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 70
Altijd: 606
