Ga door naar hoofdinhoud
Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement
Wat je nodig hebt
  1. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
    Vraag FixBot
    Voeg opmerking toe
  2. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 2, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
    Vraag FixBot
    Voeg opmerking toe
  3. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
    Vraag FixBot
    Voeg opmerking toe
  4. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 4, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
    Vraag FixBot
    Voeg opmerking toe
  5. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 5, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
    Vraag FixBot
    Voeg opmerking toe
  6. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: stap 6, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove the adhesive tape from the power connection cables.
    Vraag FixBot
    Voeg opmerking toe
  7. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 7, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 7, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 8, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 8, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 8, afbeelding 3 van 3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 9, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 9, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 9, afbeelding 3 van 3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
    Vraag FixBot
    Voeg opmerking toe
  10. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: stap 10, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: stap 10, afbeelding 2 van 2
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
    Vraag FixBot
    Voeg opmerking toe
  11. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 11, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 11, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
    Vraag FixBot
    Voeg opmerking toe
  12. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 12, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 12, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: stap 12, afbeelding 3 van 3
    • Pull the cameras out of their resting places in a straight upward motion.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
matthew vandeventer
950 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 9-4, Panko Spring 2015 Lid van Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 818
