Ga door naar hoofdinhoud
Hannspree Hannspad SN1AT71 Back Panel Replacement
Wat je nodig hebt
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 2, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 4, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 5, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: stap 5, afbeelding 2 van 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
Conclusie
4 andere personen hebben deze handleiding voltooid.
matthew vandeventer
950 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 9-4, Panko Spring 2015 Lid van Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 2,626
