Ga door naar hoofdinhoud
Handspring Visor Edge Button Board Replacement
Wat je nodig hebt
  1. Handspring Visor Edge Button Board Replacement, Flip Cover: stap 1, afbeelding 1 van 2 Handspring Visor Edge Button Board Replacement, Flip Cover: stap 1, afbeelding 2 van 2
    • Open the flip cover so that the tab on the back is easy to access.
    • Place the Visor Edge face down.
    • Identify the tab connecting the flip cover to the PDA located at the top of the backside.
    • Gently push the tab forward.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Button Board Replacement, Back Panel: stap 2, afbeelding 1 van 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Button Board Replacement: stap 3, afbeelding 1 van 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Button Board Replacement: stap 4, afbeelding 1 van 2 Handspring Visor Edge Button Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Button Board Replacement: stap 5, afbeelding 1 van 2 Handspring Visor Edge Button Board Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Button Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the white frame from the back of the PDA.
    • The frame may get stuck on the corners so be very gentle when working the corners off.
  7. Handspring Visor Edge Button Board Replacement, Button Board: stap 7, afbeelding 1 van 1
    • Pull off front cover gently.
  8. Handspring Visor Edge Button Board Replacement: stap 8, afbeelding 1 van 1
    • Remove buttons by hand, they should come off easily.
Conclusie
Nick Lazarakis
331 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-28, Maness Winter 2011 Lid van Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 720
