Inleiding
Use this guide to replace the Motherboard.
Wat je nodig hebt
Remove the outer screen cover by releasing the top clip from the main body of the device.
Remove the battery cover by releasing the clip from the main body of the device.
Use tweezers to remove the power button from the back case.
Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
Één andere persoon heeft deze handleiding voltooid.
