Ga door naar hoofdinhoud
Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement
Wat je nodig hebt
  1. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: stap 1, afbeelding 1 van 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: stap 1, afbeelding 2 van 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 2, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 2, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 2, afbeelding 3 van 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 3, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 3, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 3, afbeelding 3 van 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: stap 4, afbeelding 1 van 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: stap 4, afbeelding 2 van 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 5, afbeelding 1 van 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Back Cover: stap 6, afbeelding 1 van 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 7, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 7, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 7, afbeelding 3 van 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 8, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 8, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Button Pad and Battery Terminal: stap 9, afbeelding 1 van 1
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 10, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 10, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  11. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: stap 11, afbeelding 1 van 2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: stap 11, afbeelding 2 van 2
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  12. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 12, afbeelding 1 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 12, afbeelding 2 van 3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: stap 12, afbeelding 3 van 3
    • Use the spudger to lift the motherboard from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Faltemier
19 Reputatie
5 handleidingen geschreven
Cal Poly, Team 1-2, Regan SU 2012 Lid van Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,060
