Ga door naar hoofdinhoud
Handspring Visor Deluxe PDA Back Cover Replacement
Wat je nodig hebt
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: stap 1, afbeelding 1 van 2 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: stap 1, afbeelding 2 van 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: stap 2, afbeelding 1 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 2, afbeelding 2 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: stap 3, afbeelding 1 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 3, afbeelding 2 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: stap 4, afbeelding 1 van 2 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: stap 4, afbeelding 2 van 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: stap 6, afbeelding 1 van 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: stap 7, afbeelding 1 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 7, afbeelding 2 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 7, afbeelding 3 van 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: stap 8, afbeelding 1 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 8, afbeelding 2 van 3 Handspring Visor Deluxe PDA Back Cover Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the flex strip from the motherboard with tweezers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Robert
23 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-2, Regan SU 2012 Lid van Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 565
