Inleiding
This will walk you through replacing the microphone on the handset.
Wat je nodig hebt
After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
Remove the protective rubber cover. This may require a spudger.
