Ga door naar hoofdinhoud
Handset Microphone Replacement
Wat je nodig hebt
  1. Handset Microphone Replacement, Handset: stap 1, afbeelding 1 van 1
    • After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
    • Product is made of brittle plastic.
  2. Handset Microphone Replacement: stap 2, afbeelding 1 van 2 Handset Microphone Replacement: stap 2, afbeelding 2 van 2
    • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
    • The opening should become bigger if you exert force at a 30 degrees angle.
    • Increase the degree of slant until the back cover is completely removed.
  3. Handset Microphone Replacement: stap 3, afbeelding 1 van 2 Handset Microphone Replacement: stap 3, afbeelding 2 van 2
    • After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
    • Use a screwdriver to remove all 3 screws.
  4. Handset Microphone Replacement, Handset Microphone: stap 4, afbeelding 1 van 2 Handset Microphone Replacement, Handset Microphone: stap 4, afbeelding 2 van 2
    • After disassembling the handset, you will see the inner components of the handset.
    • Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
    • Remove the protective rubber cover. This may require a spudger.
    • The microphone is exposed upon removal of the protective rubber cover. Avoid contact with water.
Conclusie
Han Shih
361 Reputatie
4 handleidingen geschreven
IUPUI, Team 3-3, Harley Fall 2016 Lid van IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 424
