Inleiding
For more information on removing the safety valve block, please refer to section 10 in the service manual.
Wat je nodig hebt
Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
Remove Safety Valve Block
1. Disconnect the cable from the Ambient Valve Solenoid
2. Disconnect the Shaped Hose (A)
3. Remove the 2 Hex Allen Screws (B)
4. Remove the Safety Valve Block
To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
