Inleiding
This guide serves as a step-by-step replacement tutorial in replacing the internal nebulizer. First you will need to remove the rail and main cover shown in separate guides. You will need a phillips-head screwdriver and a hex-allen wrench to complete the replacement. It will take about 15-20 minutes.
For more information on replacing the nebulizer, please refer to section 10 in the service manual.
Wat je nodig hebt
Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
After the rail and main cover are taken off, remove the dark blue tubing connected to the nebulizer, pictured here.
