Ga door naar hoofdinhoud
Hamilton Beach 64650 Mixer Release Button Replacement
Wat je nodig hebt
  1. Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: stap 1, afbeelding 1 van 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: stap 1, afbeelding 2 van 3 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: stap 1, afbeelding 3 van 3
    • Depress mixer release button fully and lift mixer off of the platform.
    • Remove the bowl from the stand.
  2. Hamilton Beach 64650 Mixer Release Button Replacement: stap 2, afbeelding 1 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 2, afbeelding 2 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 2, afbeelding 3 van 3
    • Remove and set aside the three 1.3 mm Philips #2 screws holding the plastic cover in place.
  3. Hamilton Beach 64650 Mixer Release Button Replacement: stap 3, afbeelding 1 van 2 Hamilton Beach 64650 Mixer Release Button Replacement: stap 3, afbeelding 2 van 2
    • Shift the cover to allow the plastic retaining hook to fit through the hole easily.
    • Lift the cover away.
  4. Hamilton Beach 64650 Mixer Release Button Replacement: stap 4, afbeelding 1 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 4, afbeelding 2 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 4, afbeelding 3 van 3
    • Fully depress the mixer release button, pushing it through the mounting hole.
    • Push the button slightly upwards once it is inside the stand to access the spring underneath it.
    • Carefully remove the button from the stand while leaving spring in place.
  5. Hamilton Beach 64650 Mixer Release Button Replacement: stap 5, afbeelding 1 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 5, afbeelding 2 van 3 Hamilton Beach 64650 Mixer Release Button Replacement: stap 5, afbeelding 3 van 3
    • Depress the spring slightly and lift upward to remove.
    • Replace with a new spring to have a working button again.
Conclusie
Gwen Davis
519 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 7-3, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-3, Catania Spring 2016
UMASSD-CATANIA-S16S7G3
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 24
Altijd: 1,427
