Ga door naar hoofdinhoud
Hamilton Beach 51101BA Rotor Replacement
Wat je nodig hebt
  1. Hamilton Beach 51101BA Rotor Replacement, Rotor: stap 1, afbeelding 1 van 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: stap 1, afbeelding 2 van 3 Hamilton Beach 51101BA Rotor Replacement, Rotor: stap 1, afbeelding 3 van 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Rotor Replacement: stap 2, afbeelding 1 van 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Rotor Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Rotor Replacement: stap 4, afbeelding 1 van 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Rotor Replacement: stap 5, afbeelding 1 van 2 Hamilton Beach 51101BA Rotor Replacement: stap 5, afbeelding 2 van 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Rotor Replacement: stap 6, afbeelding 1 van 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Huff
616 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-5, Sullivan Fall 2015 Lid van USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Leden
6 handleidingen geschreven
3Gids Commentaar
Hi, Any idea where to get a new rotor.
Allen Reed - Antwoord
Hey! did you got the rotor?
FALGUNI SETHI -
Cómo puedo retirar la pieza blanca del rotor,si está bien socada , apretado,como detengo el rotor no de vuelta gracias
Miguel González - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 1,884
