Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
Unhinge the plastic motor platform from the blender.
Using a spudger, carefully insert the tip into the coil of wire around motor.
Remove the white rotor piece by rotating it counter-clockwise.
Move the motor platform to the side.
Lift up the motor and remove it from the blender.
Desolder the red wire from the green plastic piece.
2 opmerkingen
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Que tipo de motor tengo que comprar?
