Ga door naar hoofdinhoud
Hamilton Beach 51101BA Motor Replacement
Wat je nodig hebt
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: stap 1, afbeelding 1 van 3 Hamilton Beach 51101BA Motor Replacement, Rotor: stap 1, afbeelding 2 van 3 Hamilton Beach 51101BA Motor Replacement, Rotor: stap 1, afbeelding 3 van 3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Motor Replacement: stap 2, afbeelding 1 van 1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Motor Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Motor Replacement: stap 4, afbeelding 1 van 1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Motor Replacement: stap 5, afbeelding 1 van 2 Hamilton Beach 51101BA Motor Replacement: stap 5, afbeelding 2 van 2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
    It is not clear where to put the spudder
    Quacky Ducky - Antwoord
  6. Hamilton Beach 51101BA Motor Replacement: stap 6, afbeelding 1 van 1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Hamilton Beach 51101BA Motor Replacement, Motor: stap 7, afbeelding 1 van 2 Hamilton Beach 51101BA Motor Replacement, Motor: stap 7, afbeelding 2 van 2
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Hamilton Beach 51101BA Motor Replacement: stap 8, afbeelding 1 van 1
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Hamilton Beach 51101BA Motor Replacement: stap 9, afbeelding 1 van 1
    • Cut the thin black wire from the wire cap.
Conclusie
Andrew Huff
568 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-5, Sullivan Fall 2015 Lid van USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Leden
5 handleidingen geschreven
2 opmerkingen
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Antwoord
Que tipo de motor tengo que comprar?
hugoalex521 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 58
Altijd: 6,773
