Ga door naar hoofdinhoud
Hamilton Beach 49980A Water Tubes Replacement
Wat je nodig hebt
  1. Hamilton Beach 49980A Water Tubes Replacement, Bottom Plate: stap 1, afbeelding 1 van 3 Hamilton Beach 49980A Water Tubes Replacement, Bottom Plate: stap 1, afbeelding 2 van 3 Hamilton Beach 49980A Water Tubes Replacement, Bottom Plate: stap 1, afbeelding 3 van 3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Water Tubes Replacement, Motherboard: stap 2, afbeelding 1 van 1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Water Tubes Replacement: stap 3, afbeelding 1 van 2 Hamilton Beach 49980A Water Tubes Replacement: stap 3, afbeelding 2 van 2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
  4. Hamilton Beach 49980A Water Tubes Replacement, Main Housing: stap 4, afbeelding 1 van 1
    • After removing the motherboard. Proceed to remove the inner housing which holds the excess power cord. This can be removed by using the PH1 bit to remove the .525 inch long screws that hold the housing in the main housing.
    • This step is crucial because if this inner housing is left attached, the power cord will bind between the two pieces that slide past each other during removal of the main housing.
  5. Hamilton Beach 49980A Water Tubes Replacement: stap 5, afbeelding 1 van 3 Hamilton Beach 49980A Water Tubes Replacement: stap 5, afbeelding 2 van 3 Hamilton Beach 49980A Water Tubes Replacement: stap 5, afbeelding 3 van 3
    • Use a long screwdriver with the PH1 bit to access the screws holding the main housing to the top of the machine.
    • Pull main housing up and be sure to run all of the inner parts through the cavity at the bottom. This may take a few tries since components can easily get caught on each other
  6. Hamilton Beach 49980A Water Tubes Replacement, Water Tubes: stap 6, afbeelding 1 van 1
    • locate the bottom two spring clamps on the tube attached to the base of the coffee maker. Pinch these clips while pulling up to release the tube from the base.
    • Pliers will make this task easier
  7. Hamilton Beach 49980A Water Tubes Replacement: stap 7, afbeelding 1 van 2 Hamilton Beach 49980A Water Tubes Replacement: stap 7, afbeelding 2 van 2
    • After pushing the clips down, pull the tube from the base. This may be difficult, so use a spudger to pry the tube off as you hold the base down.
    • When replacing the water tubes, be sure to remove the apparatus from the tube on the right and insert it into the new tube.
Conclusie
Brandon Haghighi
209 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-7, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-7, Miles Spring 2016
UMASSD-MILES-S16S1G7
3 Leden
7 handleidingen geschreven
Één opmerking
Does the back pop off? Need to tighten the top water tube?
cheryl - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 2,956
