Ga door naar hoofdinhoud
Hamilton Beach 49980A Motherboard Replacement
Wat je nodig hebt
  1. Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: stap 1, afbeelding 1 van 3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: stap 1, afbeelding 2 van 3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: stap 1, afbeelding 3 van 3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Motherboard Replacement, Motherboard: stap 2, afbeelding 1 van 1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Motherboard Replacement: stap 3, afbeelding 1 van 2 Hamilton Beach 49980A Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
Conclusie
Daniel Servant
301 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-7, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-7, Miles Spring 2016
UMASSD-MILES-S16S1G7
3 Leden
7 handleidingen geschreven
Één opmerking
very informative and helpful.    I am anal about trying to repair different appliances.    I despise ‘throw away  and replace’  philosophy.   now I need to determine how to purchase a new motherboard.   at this point, I draw the line is trying to diagnosis and repair one.…………
john - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 810
