Ga door naar hoofdinhoud
Hamilton Beach 49980A Large Heating Component Replacement
Wat je nodig hebt
  1. Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: stap 1, afbeelding 1 van 3 Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: stap 1, afbeelding 2 van 3 Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: stap 1, afbeelding 3 van 3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Large Heating Component Replacement, Motherboard: stap 2, afbeelding 1 van 1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Large Heating Component Replacement: stap 3, afbeelding 1 van 2 Hamilton Beach 49980A Large Heating Component Replacement: stap 3, afbeelding 2 van 2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
  4. Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: stap 4, afbeelding 1 van 3 Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: stap 4, afbeelding 2 van 3 Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: stap 4, afbeelding 3 van 3
    • Remove the two .374 inch long Philips head screws from the brace using a PH1 bit and take the brace off.
  5. Hamilton Beach 49980A Large Heating Component Replacement: stap 5, afbeelding 1 van 1
    • Remove the second brace.
  6. Hamilton Beach 49980A Large Heating Component Replacement: stap 6, afbeelding 1 van 1
    • To remove the tubes from the large heating component, squeeze the spring clamps and slide them further down the tube.
    • Using pliers makes moving the spring clamps much easier, but it can be done by hand.
  7. Hamilton Beach 49980A Large Heating Component Replacement: stap 7, afbeelding 1 van 3 Hamilton Beach 49980A Large Heating Component Replacement: stap 7, afbeelding 2 van 3 Hamilton Beach 49980A Large Heating Component Replacement: stap 7, afbeelding 3 van 3
    • With the spring clamps moved down, slide the tubes from the ends of the large heating component. Once the ends are free, separate the component from the hot plate.
  8. Hamilton Beach 49980A Large Heating Component Replacement: stap 8, afbeelding 1 van 1
    • In order to remove the small housing that covers the motherboard, remove the lone screw with a PH1 bit.
  9. Hamilton Beach 49980A Large Heating Component Replacement: stap 9, afbeelding 1 van 2 Hamilton Beach 49980A Large Heating Component Replacement: stap 9, afbeelding 2 van 2
    • Solder the brown wire connecting the large heating component to the motherboard and remove it.
    • The wire and all following wires will be hot, so use pliers to safely handle them.
  10. Hamilton Beach 49980A Large Heating Component Replacement: stap 10, afbeelding 1 van 2 Hamilton Beach 49980A Large Heating Component Replacement: stap 10, afbeelding 2 van 2
    • Solder the white wire connecting the large heating component to the motherboard and remove it.
    • The wire will be hot, be sure to use pliers
  11. Hamilton Beach 49980A Large Heating Component Replacement: stap 11, afbeelding 1 van 1
    • Gently remove the red wire connecting the large heating component to the motherboard using pliers. If this connection is too tight to remove by hand, you may heat the solder on the bottom and remove it completely.
    • When replacing any soldered components, you may want to apply new solder.
Conclusie
Brandon Haghighi
209 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-7, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-7, Miles Spring 2016
UMASSD-MILES-S16S1G7
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 1,261
