Inleiding
This guide requires basic soldering skills and confidence working with delicate wiring. It also requires a pair of sturdy pliers.
If you are unfamiliar with soldering and de-soldering, make sure to check out iFixit's Soldering Skills page before attempting this replacement!
Wat je nodig hebt
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
Using the PH2 screwdriver and a bit of force, remove the two 10mm screws holding the thermal switch to the cooking surface.
Now pull both the thermal switch and the red wire to the back of the press, allowing easier access to the heating element leads.
Replace the missing solder.
The left lead, marked with a red circle, is connected to 2 white wires.
The right lead, marked with a yellow circle, is connected to 2 red wires.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Muy detallado, era aproximadamente lo que buscaba.
Hay posibilidades de que sea en los pasos a seguir, sean en Español. De ser así podría resolver el problema, gracias
Estoy tratando de resolver la avería de mo Sandwichera Hamilton Beach modelo 25460Z, desde mi hogar y desearía que la respuesta fuera en idioma Español, gracias
