Ga door naar hoofdinhoud
Hamilton Beach 25460Z Bottom Heating Element Solders Replacement
Wat je nodig hebt
  1. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: stap 1, afbeelding 1 van 2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: stap 1, afbeelding 2 van 2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 2, afbeelding 1 van 1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 3, afbeelding 1 van 3 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 3, afbeelding 2 van 3 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 3, afbeelding 3 van 3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 4, afbeelding 1 van 2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 4, afbeelding 2 van 2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 5, afbeelding 1 van 2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 5, afbeelding 2 van 2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
  6. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: stap 6, afbeelding 1 van 2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: stap 6, afbeelding 2 van 2
    • Using the PH2 screwdriver and a bit of force, remove the two 10mm screws holding the thermal switch to the cooking surface.
    • These screws may be difficult to remove.
  7. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 7, afbeelding 1 van 1
    • Using the PH2 screwdriver, remove the single 10mm screw connecting the red wiring cover to the cooking surface.
  8. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: stap 8, afbeelding 1 van 1
    • Now pull both the thermal switch and the red wire to the back of the press, allowing easier access to the heating element leads.
    • Replace the missing solder.
    • The left lead, marked with a red circle, is connected to 2 white wires.
    • The right lead, marked with a yellow circle, is connected to 2 red wires.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Forrest Rodeman
318 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-27, Amido Winter 2015 Lid van Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Leden
6 handleidingen geschreven
2 opmerkingen
Muy detallado, era aproximadamente lo que buscaba.
Hay posibilidades de que sea en los pasos a seguir, sean en Español. De ser así podría resolver el problema, gracias
alcides torres lopez - Antwoord
Estoy tratando de resolver la avería de mo Sandwichera Hamilton Beach modelo 25460Z, desde mi hogar y desearía que la respuesta fuera en idioma Español, gracias
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 2,974
