Ga door naar hoofdinhoud
Hair Dryer Grating Replacement
Wat je nodig hebt
  1. Hair Dryer Grating Replacement, Nozzle: stap 1, afbeelding 1 van 2 Hair Dryer Grating Replacement, Nozzle: stap 1, afbeelding 2 van 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Grating Replacement, Grating: stap 2, afbeelding 1 van 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Grating Replacement: stap 3, afbeelding 1 van 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Grating Replacement: stap 4, afbeelding 1 van 1
    • Separate the hair dryer grating into the three pieces seen in the image.
Conclusie
Mitch
37 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-29, Regan Fall 2012 Lid van Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 2,909
