Ga door naar hoofdinhoud
Hair Dryer Fan/ Motor Assembly Replacement
Wat je nodig hebt
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: stap 1, afbeelding 1 van 2 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: stap 1, afbeelding 2 van 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: stap 2, afbeelding 1 van 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: stap 3, afbeelding 1 van 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: stap 4, afbeelding 1 van 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: stap 5, afbeelding 1 van 1
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: stap 6, afbeelding 1 van 1
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: stap 7, afbeelding 1 van 1
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: stap 10, afbeelding 1 van 1
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: stap 11, afbeelding 1 van 1
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
Conclusie
Mitch
34 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-29, Regan Fall 2012 Lid van Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 16,581
