Inleiding
Is sound not playing through your speakers? You may need to replace it. This guide will show you how to remove and replace the bottom loudspeaker for the Huawei Honor 5x. If other components of the speaker is not functional then this setup may not fix your problem and you might need to contact help to diagnose the issue.
Wat je nodig hebt
Remove the six Phillips #000 screws holding the speaker to the device.
Remove the speaker
Bijna klaar!
Conclusie
