Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide describes the steps to separate the HTC myTouch motherboard from the glass screen for replacement or repair. This guide will require you to unscrew a T5 Torx screw with a VOID label. Unfastening this screw will void any warranty the phone may have.
Wat je nodig hebt
Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
While applying pressure, slide the back cover down.
Remove the four 6-mm T5 torx screws located at the four corners on the back of the phone.
Remove the two 4-mm T5 torx screws located at the middle of the back of the phone.
Dislodge the antenna cover from the phone.
Pull out the antenna cover to access the motherboard.
Insert a precision flathead screwdriver into the slit between the frame and cover, and push downward to dislodge the back plate from the phone.
Use the screwdriver to go around the edges of the phone to further dislodge the back plate.
Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
Place a finger between the circuit board and front cover, and lift up gently.
Separate the circuit board from the front cover and screen. A ribbon cable should detach.
Finish separating the circuit board from the front panel.
