Inleiding
Takes you through the steps to install the speakers.
Wat je nodig hebt
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Gereedschap gebruikt in deze stap:T5 Torx Screwdriver
Remove the four 6 mm screws with the T5 Torx screwdriver.
Bijna klaar!
Conclusie
