Inleiding
This guide will explain how to install / remove the keypad from the HTC Wizard 200.
Wat je nodig hebt
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Work the spudger around the edges of the camera cover until it comes off.
Remove the four 6 mm screws with the T5 Torx screwdriver.
Use the spudger to pry the camera off.
Using tweezers, flip the connector latch away from the motherboard.
Detach the flexible connection from under the connector latch.
Lift the motherboard out of the case using the spudger.
Expose the underside of the motherboard using your hands.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
