Inleiding
This guide takes you through the steps to install the front panel buttons.
Onderdelen
Geen onderdelen opgegeven.
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Work the spudger around the edges of the camera cover until it comes off.
Remove the four 6 mm screws with the T5 Torx screwdriver.
Use the spudger to pry the camera off.
Using tweezers, flip the connector latch away from the motherboard.
Detach the flexible connection from under the connector latch.
Lift the motherboard out of the case using the spudger.
Expose the underside of the motherboard using your hands.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
