Inleiding
This guide will explain how to install / remove the camera flash on the HTC Wizard 200.
Wat je nodig hebt
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Gereedschap gebruikt in deze stap:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Gereedschap gebruikt in deze stap:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Conclusie
