Ga door naar hoofdinhoud
  1. Deze stap is niet vertaald. Help het te vertalen
    Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
    • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
    • Pull the black tab to remove the battery.
  2. Deze stap is niet vertaald. Help het te vertalen
    Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
    • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  3. Deze stap is niet vertaald. Help het te vertalen
    Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
    • Work the spudger around the edge of the camera cover to release the clips.
  4. Deze stap is niet vertaald. Help het te vertalen
    • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
    • There is a screw under the "void" sticker.
  5. Deze stap is niet vertaald. Help het te vertalen
    Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
    • Device rotated 180 degrees.
    • Insert the flat end of a spudger into the crack between the front and rear cover.
    • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
  6. Deze stap is niet vertaald. Help het te vertalen
    Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
    • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  7. Deze stap is niet vertaald. Help het te vertalen
    Pull off the back case panel. Pull off the back case panel.
    • Pull off the back case panel.
Eindstreep
Kyle Champ
225 Reputatie
12 handleidingen geschreven
Cal Poly, Team 20-27, Maness Fall 2011 Lid van Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,052
