Ga door naar hoofdinhoud
HTC Wizard 100 Camera Replacement
Wat je nodig hebt
  1. HTC Wizard 100 Camera Replacement, Battery: stap 1, afbeelding 1 van 2 HTC Wizard 100 Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Camera Replacement: stap 2, afbeelding 1 van 2 HTC Wizard 100 Camera Replacement: stap 2, afbeelding 2 van 2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Camera Replacement, Back Case: stap 3, afbeelding 1 van 2 HTC Wizard 100 Camera Replacement, Back Case: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Camera Replacement: stap 5, afbeelding 1 van 3 HTC Wizard 100 Camera Replacement: stap 5, afbeelding 2 van 3 HTC Wizard 100 Camera Replacement: stap 5, afbeelding 3 van 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Camera Replacement, Camera: stap 6, afbeelding 1 van 1
    • Locate the camera and pry off with the plastic opening tool or spudger.
Conclusie
Kevin Gingrich
180 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-28, Maness Fall 2011 Lid van Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 779
