Ga door naar hoofdinhoud
HTC Warhawk Buttons Replacement
Wat je nodig hebt
  1. HTC Warhawk Buttons Replacement, Buttons: stap 1, afbeelding 1 van 1
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: stap 2, afbeelding 1 van 1
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: stap 3, afbeelding 1 van 1
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: stap 5, afbeelding 1 van 2 HTC Warhawk Buttons Replacement: stap 5, afbeelding 2 van 2
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: stap 6, afbeelding 1 van 1
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: stap 7, afbeelding 1 van 2 HTC Warhawk Buttons Replacement: stap 7, afbeelding 2 van 2
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: stap 8, afbeelding 1 van 2 HTC Warhawk Buttons Replacement: stap 8, afbeelding 2 van 2
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: stap 9, afbeelding 1 van 1
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
Conclusie
Caitlin Bruce
23 Reputatie
1 Handleiding geschreven
UW Stout, Team 5-3, Zhou Fall 2011 Lid van UW Stout, Team 5-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 782
