Inleiding
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  5. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  7. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  8. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  9. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  10. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  11. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool.
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  12. Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  13. Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  14. With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
Conclusie
Zhaowei Zhang
112 Reputatie
4 handleidingen geschreven
CSU Los Angeles, Team 1-6, Nelson Spring 2011 Lid van CSU Los Angeles, Team 1-6, Nelson Spring 2011
CSULA-NELSON-S11S1G6
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 3,412
