Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
First, gently press on the back plate and push down toward the camera.
Use your finger to lift up the edge of the battery.
Remove the two Phillips #00 screws from the backside of the screen.
Insert a spudger or a plastic opening tool into the seam on the side of the phone.
Gently pry apart the two halves of the phone.
Gently unplug the connectors.
Remove the screws with a 00 Phillips-head screwdriver.
Gently lift the motherboard up using a nylon spudger.
Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
