Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Lift battery upward on the upper right-hand side to remove it.
Check the battery to make sure there's no bent corners
Using a T5 screwdriver, remove the four screws in corners as shown.
Lift the top portion of the rear case.
Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
