Ga door naar hoofdinhoud
HTC Thunderbolt Volume Buttons Replacement
Wat je nodig hebt
  1. HTC Thunderbolt Volume Buttons Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Volume Buttons Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Volume Buttons Replacement, Battery: stap 3, afbeelding 1 van 2 HTC Thunderbolt Volume Buttons Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: stap 4, afbeelding 1 van 2 HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: stap 4, afbeelding 2 van 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Volume Buttons Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Volume Buttons Replacement, Rear Frame: stap 6, afbeelding 1 van 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Volume Buttons Replacement: stap 7, afbeelding 1 van 2 HTC Thunderbolt Volume Buttons Replacement: stap 7, afbeelding 2 van 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Volume Buttons Replacement: stap 8, afbeelding 1 van 1
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Volume Buttons Replacement: stap 9, afbeelding 1 van 2 HTC Thunderbolt Volume Buttons Replacement: stap 9, afbeelding 2 van 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Volume Buttons Replacement: stap 10, afbeelding 1 van 3 HTC Thunderbolt Volume Buttons Replacement: stap 10, afbeelding 2 van 3 HTC Thunderbolt Volume Buttons Replacement: stap 10, afbeelding 3 van 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  11. HTC Thunderbolt Volume Buttons Replacement, Volume Buttons: stap 11, afbeelding 1 van 1
    • Locate the side volume buttons
  12. HTC Thunderbolt Volume Buttons Replacement: stap 12, afbeelding 1 van 2 HTC Thunderbolt Volume Buttons Replacement: stap 12, afbeelding 2 van 2
    • Use a pry tool to lift the buttons out of the case
Conclusie
Vanessa
60 Reputatie
4 handleidingen geschreven
Cal Poly, Team 19-45, Regan Winter 2013 Lid van Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 558
