Inleiding
Remove the rear inner frame to gain access to the motherboard and the LCD
Wat je nodig hebt
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
Remove the two Phillips screws securing rear inner frame to device.
