Inleiding
Use this guide to replace the battery in the HTC Thunderbolt.
Wat je nodig hebt
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Één andere persoon heeft deze handleiding voltooid.
