Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the back cover of the device to access the internal components of the HTC 7 Surround. To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. Using a Phillips #00 screwdriver, remove the screws as directed. Using a Phillips #00 screwdriver, remove the screws as directed. Using a Phillips #00 screwdriver, remove the screws as directed.
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  4. Separate the screen and back cover with the opening tool.
    • Separate the screen and back cover with the opening tool.
  5. Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers. Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device. Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  6. To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device. You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  7. The SIM card slot will come off the device with the SD card slot and is ready to replace.
    • The SIM card slot will come off the device with the SD card slot and is ready to replace.
Conclusie
Michael Ronning
389 Reputatie
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 58
