Ga door naar hoofdinhoud
HTC Surround Sim Card Replacement
Wat je nodig hebt
  1. HTC Surround Sim Card Replacement, Back Case: stap 1, afbeelding 1 van 2 HTC Surround Sim Card Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround Sim Card Replacement: stap 2, afbeelding 1 van 3 HTC Surround Sim Card Replacement: stap 2, afbeelding 2 van 3 HTC Surround Sim Card Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround Sim Card Replacement: stap 3, afbeelding 1 van 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround Sim Card Replacement, SD Card: stap 4, afbeelding 1 van 3 HTC Surround Sim Card Replacement, SD Card: stap 4, afbeelding 2 van 3 HTC Surround Sim Card Replacement, SD Card: stap 4, afbeelding 3 van 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround Sim Card Replacement: stap 5, afbeelding 1 van 2 HTC Surround Sim Card Replacement: stap 5, afbeelding 2 van 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  6. HTC Surround Sim Card Replacement, Sim Card: stap 6, afbeelding 1 van 1
    • The SIM card slot will come off the device with the SD card slot and is ready to replace.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 327
