Inleiding
Follow the steps below to replace the motherboard of your HTC SMT 6175 phone.
Wat je nodig hebt
Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver.
Pull back the motherboard.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
Één andere persoon heeft deze handleiding voltooid.
