Ga door naar hoofdinhoud
HTC Radar 4G Touch Digitizer Replacement
Wat je nodig hebt
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: stap 1, afbeelding 1 van 2 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: stap 1, afbeelding 2 van 2
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery from the phone using the T5 Torx screwdriver.
  4. HTC Radar 4G Touch Digitizer Replacement: stap 4, afbeelding 1 van 1
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: stap 5, afbeelding 1 van 3 HTC Radar 4G Touch Digitizer Replacement: stap 5, afbeelding 2 van 3 HTC Radar 4G Touch Digitizer Replacement: stap 5, afbeelding 3 van 3
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: stap 6, afbeelding 1 van 2 HTC Radar 4G Touch Digitizer Replacement: stap 6, afbeelding 2 van 2
    • Use your hands to remove the touch digitizer.
Conclusie
Kevin Guerra
101 Reputatie
1 Handleiding geschreven
Texas Tech, Team 12-5, Bennett Fall 2016 Lid van Texas Tech, Team 12-5, Bennett Fall 2016
TTU-BENNETT-F16S12G5
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 256
