Ga door naar hoofdinhoud
HTC Ozone LCD Display Replacement
Wat je nodig hebt
  1. HTC Ozone LCD Display Replacement, Rear Battery Cover: stap 1, afbeelding 1 van 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone LCD Display Replacement: stap 2, afbeelding 1 van 2 HTC Ozone LCD Display Replacement: stap 2, afbeelding 2 van 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone LCD Display Replacement, Battery: stap 3, afbeelding 1 van 3 HTC Ozone LCD Display Replacement, Battery: stap 3, afbeelding 2 van 3 HTC Ozone LCD Display Replacement, Battery: stap 3, afbeelding 3 van 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone LCD Display Replacement, Frame: stap 4, afbeelding 1 van 2 HTC Ozone LCD Display Replacement, Frame: stap 4, afbeelding 2 van 2
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone LCD Display Replacement: stap 5, afbeelding 1 van 3 HTC Ozone LCD Display Replacement: stap 5, afbeelding 2 van 3 HTC Ozone LCD Display Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone LCD Display Replacement, Motherboard: stap 6, afbeelding 1 van 2 HTC Ozone LCD Display Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone LCD Display Replacement: stap 7, afbeelding 1 van 2 HTC Ozone LCD Display Replacement: stap 7, afbeelding 2 van 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone LCD Display Replacement: stap 8, afbeelding 1 van 3 HTC Ozone LCD Display Replacement: stap 8, afbeelding 2 van 3 HTC Ozone LCD Display Replacement: stap 8, afbeelding 3 van 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone LCD Display Replacement, LCD Display: stap 9, afbeelding 1 van 2 HTC Ozone LCD Display Replacement, LCD Display: stap 9, afbeelding 2 van 2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone LCD Display Replacement: stap 10, afbeelding 1 van 1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone LCD Display Replacement: stap 11, afbeelding 1 van 2 HTC Ozone LCD Display Replacement: stap 11, afbeelding 2 van 2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone LCD Display Replacement: stap 12, afbeelding 1 van 1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone LCD Display Replacement: stap 13, afbeelding 1 van 1
    • Lift the Motherboard away from the LCD display.
Conclusie
Marco Jokada
247 Reputatie
6 handleidingen geschreven
CSU Los Angeles, Team 1-2, Nelson Spring 2011 Lid van CSU Los Angeles, Team 1-2, Nelson Spring 2011
CSULA-NELSON-S11S1G2
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,221
