Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the phone over to have the rear cover facing up.
The camera lens should be towards the top of the phone.
Slide the cover up, towards the top of phone, to unlock the battery cover.
Lift the cover off phone and remove it.
Use your finger to push the top of the battery downwards and lift the battery out of the phone.
Remove the six Torx #5 screws that are securing the rear frame.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99-
Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
Één andere persoon heeft deze handleiding voltooid.
