Ga door naar hoofdinhoud
HTC One X Plus Motherboard Replacement
Wat je nodig hebt
  1. HTC One X Plus Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: stap 2, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 2, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: stap 3, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 3, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: stap 4, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 4, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: stap 5, afbeelding 1 van 2 HTC One X Plus Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: stap 6, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 6, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jason Melo
483 Reputatie
4 handleidingen geschreven
USF Tampa, Team 3-3, Eyestone Fall 2015 Lid van USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,233
