Ga door naar hoofdinhoud
HTC One X LCD Display & Touch Screen Glass Digitizer Replacement
Wat je nodig hebt
Video overzicht
  1. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: stap 1, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: stap 1, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement, LCD Display & Touchscreen: stap 1, afbeelding 3 van 3
    • Switch-off the phone (if you can).
    • Remove the SIM tray.
    • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
  2. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 2, afbeelding 3 van 3
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 3, afbeelding 3 van 3
    • The mother board is held by 6x Philips screws.
  4. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 4, afbeelding 3 van 3
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Use a plastic tool to unstick the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  5. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 5, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 5, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 5, afbeelding 3 van 3
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery from the mainboard.
  6. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 6, afbeelding 3 van 3
    • At the beginning you can use a cutter to make a room for the plastic tool.
    • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  7. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 1 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 2 van 3 HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 7, afbeelding 3 van 3
    • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
    • Gently assemble the screen to the frame.
  8. HTC One X LCD Display & Touch Screen Glass Digitizer Replacement: stap 8, afbeelding 1 van 1
Conclusie
14 andere personen hebben deze handleiding voltooid.
ZFix
191.182 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
Één opmerking
i need touch panel do you have available
osama siddique - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 38,259
