Inleiding
If phone will not vibrate, vibrates slightly or vibrates sometimes, a faulty vibrator could be the issue.
Wat je nodig hebt
Power off your device.
Remove the bottom cover by sliding it off.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
