Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Power off your device.
Remove the bottom cover by sliding it off.
Remove the SIM card.
Remove the four screws securing the bottom casing.
Two 3.0 mm Phillips #0 screws in the top left and right corners.
Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
Remove the 2.0 mm Phillips #0 screws on either side of the phone.
Use a plastic opening tool to pry open the bottom casing.
Remove the bottom casing by pulling it towards you.
Using a plastic opening tool, peel off the speaker cover.
Use the spudger to push the speaker out of its casing.
