Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If you have an issue with your speaker as stated in our troubleshooting page ( HTC One M7 Troubleshooting ) then this guide is for you.
  1. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel. Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. Pry the back loose and lift. The back panel will come off with time.
    • Pry the back loose and lift. The back panel will come off with time.
  3. Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Use tweezers to get underneath the motherboard to lift.
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  6. Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  7. Remove the motherboard completely out of the phone. May stay attached from one end by tape.
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  8. Use the blue opening tool to pry the battery from the frame. Some force will be needed since the battery is glued to the frame.
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  9. Completely remove the motherboard. Completely remove the motherboard. Completely remove the motherboard.
    • Completely remove the motherboard.
  10. Remove the #000 screws around the speaker that are located at the bottom of the frame. Lift the speaker out of the frame.
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Alex
664 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-1, Blackwell Fall 2014 Lid van USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Leden
7 handleidingen geschreven
Ok I will good
Raguraman - Antwoord
Where to buy speaker???
bharatdshmkh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 18,888
