Ga door naar hoofdinhoud
HTC One Mini Screen Replacement
Wat je nodig hebt
  1. HTC One Mini Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Use a plastic opening tool to remove the bottom speaker cover
  2. HTC One Mini Screen Replacement: stap 2, afbeelding 1 van 1
    • Use your T6 Torx screwdriver to remove the single screw that holds the body to the aluminium back
  3. HTC One Mini Screen Replacement, This step requires a little patience: stap 3, afbeelding 1 van 2 HTC One Mini Screen Replacement, This step requires a little patience: stap 3, afbeelding 2 van 2
    • Use only plastic opening tools, metal ones will cause damage to the assembly
    • Use a plastic opening tool next to the usb port to gently lift the bottom away from the backing.
    • Use a second tool to work your way around the phone undoing the clips while the first tool lifts the undone areas
  4. HTC One Mini Screen Replacement: stap 4, afbeelding 1 van 1
    • Use your heat gun and infra-red thermometer to heat the screen assembly to 130 degrees C (265 F) to soften the adhesive
    • Use opening tool to gently lift the edges of the screen away from the body working from the top down.
    • Don't try to remove the bottom of the screen as your flex cables are there and still attached to the logic board
  5. HTC One Mini Screen Replacement: stap 5, afbeelding 1 van 1
    • Undo the 2 Phillips screws circled in red and detach the battery connector (so we don't short anything out)
    • Undo the 3 screws holding down the bottom of the logic board and charger port circled in green
    • Undo the flex cables and speaker power cable circled in blue and lift the charger port out
    • The flex cable for this board and the one next to it for the screen their locking tabs open from the back
    • Gently using a plastic opening tool lift out the bottom speaker
    • Also the rubber spacer circled in blue
    • Undo the flex cables circled in orange and slowly start pulling the old screen out
  6. HTC One Mini Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove any old adhesive and broken glass from the frame
    • Gently feed through the flex cables taking great care not to break them
    • Don't remove any of this sheilding tape, I have only removed it to show you that there is nothing under there and I have replaced it during reassembly
  7. HTC One Mini Screen Replacement: stap 7, afbeelding 1 van 1
    • Fold the screen away from the body keeping in mind not to damage the flex cables.
    • Add your strips of adhesive tape to the frame and put put the screen onto the body (I have highlighted the placement areas in blue)
    • You will have to cut the tape in half for the sides of the screen. Using a razor blade and a metal ruler will give best results.
    • Follow the steps in reverse for reassembly and use a couple of drops of super glue to put the front speaker cover back on
Conclusie
10 andere personen hebben deze handleiding voltooid.
Robbie
655 Reputatie
1 Handleiding geschreven
2 opmerkingen
I just need to change the touch digitizer, how do I detach it from the LCD?
hudeor - Antwoord
Where can i find a replacement screen
pietro.faraggiana - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 37,003
