Ga door naar hoofdinhoud
HTC One Mini Motherboard Replacement
Wat je nodig hebt
  1. HTC One Mini Motherboard Replacement, iOpener Heating: stap 1, afbeelding 1 van 1
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. HTC One Mini Motherboard Replacement, Remove Speaker Grills: stap 2, afbeelding 1 van 1
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. HTC One Mini Motherboard Replacement, Remove Screw: stap 3, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove Screw: stap 3, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove Screw: stap 3, afbeelding 3 van 3
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. HTC One Mini Motherboard Replacement: stap 4, afbeelding 1 van 3 HTC One Mini Motherboard Replacement: stap 4, afbeelding 2 van 3 HTC One Mini Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. HTC One Mini Motherboard Replacement, Separate Rear Case: stap 5, afbeelding 1 van 2 HTC One Mini Motherboard Replacement, Separate Rear Case: stap 5, afbeelding 2 van 2
    • Remove the rear case from the phone.
  6. HTC One Mini Motherboard Replacement, Remove Screws: stap 6, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 6, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 6, afbeelding 3 van 3
    • Remove the two Phillips screws securing the battery connector.
  7. HTC One Mini Motherboard Replacement: stap 7, afbeelding 1 van 2 HTC One Mini Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the battery by prying the metal cover straight up.
  8. HTC One Mini Motherboard Replacement, Remove screws: stap 8, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove screws: stap 8, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove screws: stap 8, afbeelding 3 van 3
    • Remove two Phillips screws.
    • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
  9. HTC One Mini Motherboard Replacement, Remove Screws: stap 9, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 9, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 9, afbeelding 3 van 3
    • Remove the two small black Phillips screws.
  10. HTC One Mini Motherboard Replacement, Remove Screws: stap 10, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 10, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove Screws: stap 10, afbeelding 3 van 3
    • Remove two more Phillips screws.
  11. HTC One Mini Motherboard Replacement, Remove protective foil.: stap 11, afbeelding 1 van 3 HTC One Mini Motherboard Replacement, Remove protective foil.: stap 11, afbeelding 2 van 3 HTC One Mini Motherboard Replacement, Remove protective foil.: stap 11, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
  12. HTC One Mini Motherboard Replacement: stap 12, afbeelding 1 van 2 HTC One Mini Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  13. HTC One Mini Motherboard Replacement: stap 13, afbeelding 1 van 3 HTC One Mini Motherboard Replacement: stap 13, afbeelding 2 van 3 HTC One Mini Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
  14. HTC One Mini Motherboard Replacement: stap 14, afbeelding 1 van 2 HTC One Mini Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
  15. HTC One Mini Motherboard Replacement: stap 15, afbeelding 1 van 3 HTC One Mini Motherboard Replacement: stap 15, afbeelding 2 van 3 HTC One Mini Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
  16. HTC One Mini Motherboard Replacement: stap 16, afbeelding 1 van 2 HTC One Mini Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
  17. HTC One Mini Motherboard Replacement: stap 17, afbeelding 1 van 3 HTC One Mini Motherboard Replacement: stap 17, afbeelding 2 van 3 HTC One Mini Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
Conclusie
Daniela Delgado
577 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-4, Brown Fall 2014 Lid van USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 5,056
